Hello,
I want to iterate through table records that are passed as a parameter between class objects. I want to avoid performing a selection again.
Thank you!
Hello,
Thank you!
will you describe little more.
In some cases, you can use the following syntax:
Table1 table1 = args.record();
while (table1)
//do something
next table1;
But be careful on which tier it runs (especially you cannot fetch data on client and call “next” on server).
Or you could use a Record*List object, pass the query object instead of a buffer and so on.
