Transferring items from location to location
Hi All I have a problem with transferring items from one location to another. If the location I’m transferring from doesn’t contain enough, say boxes o’ stuff, I get an error. Elsewhere in Navision there’s no problem in using a negative inventory quantity. Why this error message. Its codeunit 22, when im using the Inventory->Item Reclass Journals. Henrik
You cannot transfer what you’re not having. Try a positive adjustment and a negative one instead. Regards,
I was afraid of that. Thanks anyway.
