Transfer - set Financial Dimension -> From Dimension
I’m trying to add lines from code to a transfer [inventJournalTrans] _journalTrans. I can’t figure out how do I add Financial Dimension through code.
I need to set one financial dimension (site) based on ‘_fromInventDimId’ site value.
_journalTrans.clear();
_journalTrans.initValue();
_journalTrans.JournalId = _journalTableData.journalTable().JournalId;
_journalTrans.ItemId = _itemId;
_journalTrans.InventDimId = _fromInventDimId;
_journalTrans.ToInventDimId = _toInventDimId;
_journalTrans.Qty = _qty;
_journalTrans.JournalType = InventJournalType::Transfer;
_journalTrans.TransDate = _date;
_journalTrans.create();
Any suggestions?
See how the default dimension is set here,
http://axaptacorner.blogspot.in/2012/09/how-to-create-general-journal-in-ax.html
Thanks for your effort, Apparently, solution was very simple, maybe I didn’t describe my problem so well.
InventSite inventSite;
InventDim siteInventDim;
siteInventDim = InventDim::find(_fromInventDimId);
select DefaultDimension from InventSite where InventSiteId == siteInventDim.InventSiteId;
_journalTrans.DefaultDimension = inventSite.DefaultDimension;
Thanks again.
