Transfer Order
I make a Transfer order with 10 Quantity after shipped receive is Partially in order 6,3 and 1. if i receive 6 then received.if i receive 3 then system shows a error suppose that amount 12.1232323 needs to be rounded. if i check through the debugger this code give the error. i checked the standard Database.
IF “Additional-Currency Posting” = “Additional-Currency Posting”::None THEN BEGIN
IF Amount <> ROUND(Amount,Currency.“Amount Rounding Precision”) THEN
FIELDERROR(
Amount,
STRSUBSTNO(Text000,Amount));
IF “Amount (LCY)” <> ROUND(“Amount (LCY)”) THEN
FIELDERROR(
“Amount (LCY)”,
STRSUBSTNO(Text000,“Amount (LCY)”));
End
I want to receive Partially.
Have you check both the amount while in deburg mode.
Amount is 0.00428571428571. and Currency.“Amount Rounding Precision” is 0.01
then value is not equal 0.00428571428571<>Round(0.00428571428571,0.01) then shows the error.
And what about Amount LCY ?
Error shows in this line (Amount<>round(Amount,Currency.“Amount Rounding Precision”)
Amount (LCY ) value is same as Amount and this condition also true.
What NAV ver ?
NAV 2009 R2
Tries your scenario but no error ?
Check your setup or if any customization done.
Currently, I am doing standard Database(CRONUS-NAV 2009 R2).Quantity shipped 20
Quantity Received 19 and then again Qty to receive 1 Qty then shows a error screen shot is attached
Amount is 1670.575 and Round Amount 1670.58 not equal then shows a error.
http://dynamicsuser.net/members/smishra/files/To-error1.bmp.aspx
Yes, the error occurs.
After debug found that in codeunit 5705 under FillTransferBuffer function when inserting the value in amount, the amount is not rounded.
Below is the code
TransferBuffer[1].Amount := (Amount - ROUND(“Unit Cost” * “Qty. to Receive”));
You can modify the code if require to round the value and check.
Thanks for information.
I am also receiving the same error, but i have changed the code as you told,
TransferBuffer[1].Amount := Round((Amount - ROUND(“Unit Cost” * “Qty. to Receive”)));
now it’s posted successfully.
Muthukumar R
