Transfer order not getting "Receive" after adding Financial Dimension I .
I discussed it with functional guy and according to him all is well at setup side… I tried to change the Dimension setup for Allow blank all and it’s work fine but with dimension combination it’s creating problem…
We are giving same combination which we are selecting in our Dimension values .
I am thinking to skip the validation :stuck_out_tongue: … Is it a good idea :smiley:
validation held on “LedgerVoucherTransObject \ Check” .
You shouldn’t be doing that.
Have you tired to post a ledger journal to check if the dimension and ledger combination is really correct? Just to confirm.
For ledger journal it’s going but for transfer from one location to another it’s not taking additional dimension … Although Functional is going for another Workaround but I want to finish this requirement also.
Try to debug both the processes to see why only one process return error and other not?
