I am trying to transfer the opening balances to new year , in the process i have opened the Opening transactions form and in the end date field value is showing as 12/1/2006 and click Ok . System throws the following error as End date must be a closing date. The closing date of the year is 11/30/2007.
Even i entered the date as 11/30/2207 , still system takes the date as 12/1/2006.
In your post you mentioned the given date as "11/30/2207" which is not the prompted date by the system. I guess its a typo when you tried in the system. set it to "11/30/2007".
Below is the data from the Accounting periods form in AX 2009
Start Period code End Status
12/1/2006 Opening 12/1/2006 Closed
12/1/2006 Normal 11/30/2007 Open
11/30/2007 Closing 11/30/2007 Stopped
12/1/2007 Opening 12/1/2007 Closed
12/1/2007 Normal 11/30/2008 Open
It seems you are using default database provided for AX. please check the license expiry date for same. Generally date issue occurs when you license is expired.
