transfer of asset from one financial dimension to another
can anybody suggest the solution for the below requirement
asset is purchased in one store (store is financial dimension) and run the depreciation also for few months then transferring of the same asset to another store
i need to move the acquisition, depreciation transactions from store to to store
Please suggest me best solution for the above requirement
Regards
siddu
Can you please share the Version of AX you are using?
Hi Sachin,
thanks for ur replay
i am using axapta2012
Regards
siddu
There is a functionality available to cater this requirement. Transfer button is available at Fixed Asset Master form. Where you can pass the necessary transactions for effecting Transfer of Fixed Assets
Hello Sachin,
How to see Financial Dimension wise Assets Acquisition Report?
Is it possible to see in AX 2012?
