I want to Transfer object from W1 4.0 to IN Nav 2009 ,there are some customized objects as well as some base navision objects are modified as per requirement . hole development has been done in a W1 4.0.
So what are the prosedure to convert W1 4.0 to IN 2009.
Actually we are developed database for a foreign client, but for a Indian client we are going to impliment almost same thing.So we need W1 4.0 to IN 2009.
So it means you developed some functionality/ enhancement/ customization in Navision 4.0 W1 version and you want to do same thing in NAV2009 IN.
So it is not the upgrade of the database (which I thought from your previous post).
You need to identify the objects changed/ newly developed in NAV4.0 W1 database and incorporate those changes in NAV2009 IN database.For this you should have a understanding of the changes and check if these changes are part of new database, if yes then you can skip those changes.
