Hi, Has anybody worked with the Transactional Replication (with Immediate Updating Subscribers) for MS SQL Server 7.0? We are using Navision Financials W1 2.60B, and two servers in a LAN. One server is the Distributor and Publisher, the other server is the Subscriber. We had some problems during set-up, e.g. invalid table- and fieldnames, but we solved most of them. Now we have difficulties when we change the Navision-database design (using Navision as front-end) when replication is active: when a table is changed and we try to save it, a Navision/SQL error occurs and tells that there were problems modifying the design in the replicated table. Any ideas? Thanks, Bart Bolkestein
