To NAV Expert
Is the system capable of tracing who’s user deleted posted document?
If possible, please advice where I could see the name of user deleted such document.
Thank you!
To NAV Expert
Thank you!
If you have activated Change Log then it is possible…
Fllow the navigation below…
Administration->IT Administration->General Setup->Change Log Setup.
Place a tick mark in the field “Change Log Activated”
Then Click
Setup->Tables.
here you can selsct the table for which you want the changelog
Options are --. Log Insertion/Log Deletion/Log Modification
If you select Some fields then click assist edit to select the fields for which you want to maintain the changelog.
/Anup
Hi Anup
Thank you so much. It helps me a lot.
