I have a question about TOTALSCAUSEDBY function, i can’t use this function in nav2013. Is there similar function to this in nav 2013 or some workaround in order to achieve the same functionality of Totalscausedby. I have a report in 2009 that i should migrate in Nav2013 ,but there is visibility and some code execution that depends of this fiction. So is there a way can i replace it with.
BR
In RDLC there is a specific header/footer for every group, so you don’t need this function anymore because you can control the visibility inside the specific group.
Thanks You very much for your reply.
Yes but, I have complex key for the data item (key contains 3 fields). So only if total is caused by the third field then should visibility be true and certain code to be executed. I can’t menage that in RDLC, how can I now which field of the key change its value so therefore causes calculation of group totals and visibility. Is it clear what are my doubts or should I explain more.
Thanks in advance
