I want to ask with which function in NAV7 is repaced TOTALSCAUSEDBY function from Nav 6.
ex: How can be implemented this in NAV7:
CurrReport.SHOWOUTPUT(CurrReport.TOTALSCAUSEDBY = “Table1”.FIELDNO(“Field 1”));
Thanks in Advance
Thanks in Advance
totalscausedby is no longer working in nav 7.
where do you want to use this in nav 7… in groupfooter may be to show the footer section…?
NAV 7 MAKE THE GROUPINGS INDIVIDUAL THEN SHOW ONLY THOSE FOOTER WHICH HAVE THE SUM VALUES…?
this is just a workaround… if you can share the problem in detail… i can try to help you,.
Anil.
Yes,this is for group header and for group footer. I found how to implement this in VS, but I have export excel too(and that should be made by code).
I have two groups one by Field1, and other one ,intended, by Field 2:
HeaderGroupbyField1
RecGroupbyField2
RecGroupbyField2
RecGroupbyField2
FooterGroupbyField1
In CC showing of Header/FooterGroupByField1 is controlled by :
end filling in excel file works ok (IF(SHOWOUTPUT) Then enter Header/FootherGroupbyField1) in excell file(Buffer)-This code is on section)
But how can I tell in Nav 7,by code, that if grouping is by Field1…then print header from first group?
This code should be OnAfterGetRecord. By now I am getting this result in ExcellFile:
HeaderGroupbyField1
RecGroupbyField2
FooterGroupbyField1
HeaderGroupbyField1
RecGroupbyField2
FooterGroupbyField1
HeaderGroupbyField1
RecGroupbyField2
FooterGroupbyField1
