May i know how will i resolve the error message : the field specified in the totalfield property must be a decimal. When i checked the field properties the field that i want to total was categorized as an integer.
Hoping for your assistance.
The message …
… clearly says that the field that you want to used in the TotalFields property should be of (data) type Decimal, so you cannot use a field of type Integer.
So either the field (data) type should be changed from Integer to Decimal, but I am not sure if this possible/allowed (this can be far reaching so do not, repeat not, do this just like that) or you could declare a variable of type Decimal in which you calculate the total of the field values using for example the CREATETOTALS function`.
Hi Guys,
Am facing Same Problem Please any one one help me Out.
Did you read Luc’s post?
Hi sir,
Just Now I solved.
Ashish
