Top Vendor List to include more Vendors
Using NAV 2009 SP1
I followed this post http://dynamicsuser.net/forums/t/32079.aspx add more vendors to the Top __ Vendor List and bumped it up to 300
going to SwapAmt, SwapText, SwapCode – then locals, then shift f4 and changing the dimensions to 300… I also changed the print loop max iteration to 299
Under options when i enter ‘No. of Vendors to Rank’ = 200 i receive the error Number of vendors must be less than 100.
Where would i be missing a step to complete this?
view the request form
click on the field where you enter the number of vendors.
hit f9 you should see:
OnValidate()
IF VendorsToRank > 99
THEN ERROR(‘Number of vendors must be no greater than 99’);
Ah yes that was the key finding the request form… the code was
IF NOT (VendorsToRank < ARRAYLEN(TopNo)) THEN
ERROR(Text008,ARRAYLEN(TopNo));
but i had the error the orig. post link above mentioned so…
I went into the globals and changed TopNo., TopAmount , TopBalance, TopPurch all to a dimension of 300
THANKS :slight_smile:
