Hi all, is it possible to disable tooltips permamently under attain 3.10, although you can disable it via the tools menu, it can be re-activated upon deletion of the zup file. So can this be done programmatically ? Tooltips cause the CPU usage on a citrix server (with attain clients) to rocket to 50% - 1user or 100% - 2users. Thanks
Hi, As per my knowledge you can not do it programatically.
Or upgrade You exe’s to latest version and get rid of the problem /Lars
there is a tool called “threadmaster” with which we control the problem until every client has 3.7 … have a look at http://threadmaster.tripod.com/
