tool costing in Production
How can reuse tools costing add impact in production…
Example.
If Cost of tool is Rs. 2000 and life is 1000 cycles.
After 1000 cycles tool regrind and cost of regrind is Rs 50 and life is Rs.900.
After 900 cycles tool regrind and cost of regrind is rs. 50 and now life is 800.
this continue till life is 100.
How to calculate tool cost per piece and how to map this in production ?
How can reuse tools costing impact on production…
Example.
After 1000 cycles tool send for regrind and cost of regrind is Rs 50 and life will be 900 cycles.
After 900 cycles tool send for regrind and cost of regrind is Rs. 50 and now life is 800 cycles.
this continue till life of toll will be 100 cycles.
Depends upon the version of AX - AX2012 you would add it as a tool, you would need to calculate the life cost of the product which you basically have there and then divide by the cycles to get a cycle cost and then at it into the route at this cost with the appropriate cycle/hr setting on the tool.
