I know Navision doesn`t allow to undo a resource line from any shipment as items but, is there any posibility to correct those lines about resources?.
Thank you.
Thank you.
Hi Jimmynd,
Have you tried invoicing and then posing a credit memo for the resource?
hi Dave,
Yes, I know it but we don`t create a new invoice for this reason. Any idea?.
Thanks.
Hi Jimmynd,
If I understand you correctly - you do not want the customer to see the shipped resource line.
I suggest you enter an invoice and use the get shipment lines and delete the resource line ( or just select the item line) and post the invoice.
Then post a second invoice at zero price to clear the resource shipping line.
hi DaveT,
Yes, but if we do that you propose, that resource line is open in the shipment document. I want to undo the resource line (as item lines) from the same shipment document to close that document line. I think standar version isnt possible, but I don
t know if there would be any problem if we develop code.
Thanks.
Hi Jimmynd,
Don’t see any problem coding this.
ok, thanks DaveT
