Recently I have a requirement where I have to check whether a financial dimension has dimension values other than “Main account” like “Cost center, Department” etc, while creating a GL journal.
Below is the code which returns a Int64 recId if the given dimension value has atleast one dimension value other than main account, otherwise it will return ‘0’.
Based on that I have to check, if the financial dimension coming from the file doesn’t have dimensions other than Main account, I have to merge the default dimensions of the main account while creating a GL journal line.
if (!DimensionStorage::getDefaultDimensionFromLedgerDimension(_ledgerJournalTrans.LedgerDimension))
The below method takes 2 parameters:
DimensionDefaultingService::ServiceCreateLedgerDimension(Parameter 1, parameter 2);
Parameter 1) RecId of the Current dimension that needs to merge.
Parameter 2) Main Account default dimension recId.
To find the Main account default dimensions recId use this method:
MainAccountLegalEntity::findByMainAccountLegalEntity(Parameter 1, parameter 2)
Parameter 1) RecId of the Current MainAccount.
Parameter 2) Current company reci Id.
This is how the code will look like:
_ledgerJournalTrans.LedgerDimension = DimensionDefaultingService::ServiceCreateLedgerDimension(_ledgerJournalTrans.LedgerDimension,
MainAccount::findByLedgerDimension(_ledgerJournalTrans.LedgerDimension).RecId,
CompanyInfo::findDataArea(curext()).RecId).DefaultDimension);
Best Regards
Pranav Gupta
