timing
Does anyone have ideas about executing a function based on time? We need navision to check if an external file exists and if it does, do some processing. I’m not sure on the time requirements but we need to be sure it gets done.
It’s a bit depending on the interval. If the interval is rather short (minutes), you could use the OnTimer trigger from a form (likely the Main Menu). If the Interval is i.e. once a day, you are probably better off with an external timer or scheduler. If you can use the SQL version of Navision, you can get extra functionality from the SQL Scheduler and stored procedures, but that’s a bit more complicated story. John
