Within our citrix enviroment, we can force people(thin clients) who are idle for more then 15mins, upto 2 hours idle, off the system, in a controlled fashion. However, we are now bringing on clients who are local(fat client), to the Navision server, and we are concerned that we will not be able to control the sessions as easily as we could with the thin clients. Does anyone have this sorta problem already? Or hopefully perhaps even solved it? I have searched the forums for automatic logout, and nothing helpful has turned up. I have tried the Task Terminator tool, which may work after careful configuration, but was unable to find any links to the SQL_DB tools mentioned in one of the topics. Regards
Check www.mibuso.com - should be available from 3.60 up. Tõnu
Unfortunatly we are stuck in limbo on version 3.01B, and plans are in place to move to the latest version, but this is not until version 4 I think [:(]
