We are executing some SQL statements in ax database and fill the data in the excel sheet by using vb.net application.
Sometimes, we are getting SQL time out error. I have mentioned SQL command timeout time 600 seconds. But, still I am getting the same error. Is there any extra connection settings available for using ax database?
Error: Timeout expired. The timeout period elapsed prior to completion of the operation or the server is not responding.
Hari
is it a windows or web app ? are u using ADO.NET or Entity framework or … ?
How do you execute the statement? By SqlDataReader or something?
Thanks for your reply. It is windows application.
I am executing the query by using the below code.
Dim dscmd As New SqlDataAdapter(SQLScript, cnn)
Dim ds As New DataSet
dscmd.SelectCommand.CommandTimeout = 600
dscmd.Fill(ds)
Hari
It may be the timeout for the whole connection and not just the individual command.
try to add the below to the connection string
Connection Timeout=600
