Time import from excel
Hi ,
i try to import time in ax table through excel
i use following code
table_field_name = str2time(cells.item(i,1).value().bstr())
but in table update ‘?’ (question mark)
second i use
table_field_name = cells.item(i,1).value().time()
but in table update 00:00:00
suggest how to import time through excel
U can refer to this job and based on ur Input paremeters, use the related Function
static void any2DateExample(Args _args)
    date myDate;
    str s;
    int i;
    s = "2010 6 17"; // A string object, of yyyy mm dd.
    myDate = any2Date(s);
    Global::info(strFmt("%1  is output, from input of \"2010 6 17\"", myDate));
    i = 40361; // An int object, which represents the number of days from 1900/01/01.
    myDate = any2Date(i);
    Global::info(strFmt("%1  is output, from input of 40361", myDate));
/**** Infolog display.
Message (04:44:15 pm)
6/17/2010 is output, from input of "2010 6 17"
7/4/2010 is output, from input of 40361
HI
Thanks to reply
but i make class and import that value from excel so how to use this class
