My client use NAV2009 R2 W1+ Manufacturing;
This is the scenario;
Work center B has assigned to production item A.
Work center B;
It is a oven.It can hold 1000 items at a time.Its holding time will vary item to item.
its 2 hours for item A.
now i have 3 production orders. each 120 of item A, 200 of Item A and 300 of item A regularly.
Whole quantity of item A(620) work center run time is 2 hours. (Qty 1 to 1000 its 2 hours).
how can i set the time in route card?
I need to set the time to calculate accurate time at the planning worksheet.
your comments are highly appreciate.
Hi Ashoka,
You can specify the “Maximum Order Quantity” to 1000 and then on the Route specify the “Minimum Process Time” as 120 minutes.
