i have two fields in my form,i need to validate in such a way that i should not allow to get the record saved unless i enter values for either of the field…how to do?
Rajee
Rajee
In validatewrite method of the table
add the code:
if((field1 == ‘’ ) || (field 2 == “”))
throw error(“enter values”)
regards
Shon
But shon, i did the samething to another form …but i dint show me any error msgs
one clarification, do i need to use “ValidateWrie” in the table or the in the form datasource?
form also it shoul work, but i would also suggest you to override the table-validatewrite method
and write smthing like ret = checkfailed("no values ")
Regards
Shon
I agree with you shon,but i’m not getting it. my requirement is in the ‘AdressCountryRegion’ form, the record should’nt get saved unless i enter content in the ‘description’ field …can u please help
so raji - did u try by over riding table validate write method.??
if not
jus use this code
public boolean validateWrite()
boolean ret;
ret = super();
if(this.Name == ‘’)
ret = checkfailed(“no values”);
return ret;
trust me it wil work.,
regards
Shon
Shon, Correct me if i’m wrong
in the Form datasource ,i’ve written
boolean ret;
ret = super();
if(AddressCountryRegion.description== " ")
box::info(“please enter values”);
return ret;
then as you have told,i overrid the validatewrite method in the AddressCountryRegion table also,but still i’m stuck up
Hi rajarajeshwari,
In Form AddessCountryRegion – DataSource – methods – overide the validatewrite method…
boolean ret;
ret = super();
if(!AddressCountryRegion.Name)
ret = checkfailed(“Enter the %1”,AddressCountryRegion.Name);
return ret;
try this it may help you out…
Naresh Kolli
Thanks for the help Shon and Naresh
-Rajee
