this error show when open dynamic nav 2009r2
Hi guys when i open dynamic nav 2009r2 this error show to me
" the following odbc error occurred error [Microsoft ][odbc sql server driver] timeout expired state id hyt00
Kindly try this
http://mibuso.com/blogs/kriki/2008/04/05/local-sqlserver-2005-with-windows-authentication/
This problem some times made before and come again without any thing and also my computer in domain not work group and i check tcp/ip it is enabled. and when this message made one user open and another user in network not open dynamic why and how i solve i dont know
Add your Server IP address and name in hosts file under
C:\Windows\System32\drivers\etc and try…
OK if enable of named pipes is the reason to make this problem or this no related to problem
thanks
IS your problem resolved ??
No
Did you try by adding IP Address?
I added in server only
thanks for reply
You need to add server IP in Client machine not in server…
OK guys thanks more time for help.I appreciate your help
What do you mean by this?
you should be clear whether your problem got solved or not.
ok solved
Can you share the solution with us so that it can help others
