HI, Iam using three dimensions based on my company requirement. But iam unable to get Balance sheet and P&L statements based on third dimension. Even in the form there is a provison for 4 dimensions. Can any body help regarding this matter. Thanks in advance Mahesh K [?]
Hi Mahesh Make sure you have updated you analysis view. The standard reports in navision do not use any dimensions except for global 1 and 2. To print a balance sheet or P&L with the third dimension you will need to create an account schedule and link it to your analysis view, then either print or export to excel. Also, you might have a look at Jet Reports which is very good for reporting especially allowing the extra dimensions to be reported. Cheers Peter
