thin client with barcode reader
Does anyone have experience of using a barcode reader with a thin client? We tested Keytronics thin client unit with its wand reader (its only available reader) and the reslults were not satisfactory. Anyone has any other recommendations? Thanks. Scott
Hi, we are using a barcode scanner from ChipperLAB on a Wye1200LE thin terminal. No problems, but the scanner is really slow. I think that every barcodescanner that connects via USB could work on the 1200LE terminal. /Andreas
Andreas, Thanks for your reply. Do you know why the scanner is slow? Is it because of the scanner or the thin terminal? Regards, Scott
