The worker is not assigned to a position for this pay period. Assign the worker to a position to generate earnings. in AX 2012
Hi frnds,
When i click the Earnings statement Lines to create a Earning statement in Payroll module that time i got some struck with this below mentioned error. If any one know plz let me know.
“The worker is not assigned to a position for this pay period. Assign the worker to a position to generate earnings.”
But i assigned Worker to that particular Position.
You said that assigned the worker to the position, but check if you did it for the right period.
if i am not wrong this is also based on the work calendar assigned to this worker, you can check that also if it correctly setup or not.
