When i create a new purchase order, i select vendor account, location id etc, when i select warehouse, That error is coming…Plz help me out to solve this issue
Are there any changes(to the existing logic) here?
Hi Kranthi,
There are no changes in logic… This is just Std Ax 2009… And also, this error is there for all the company data…Not only for single company data… Thanks for ur help in advance Kranthi …
I think that there is server error or error in your internet connection.
What has internet connection got to do with this error? [:)]
Get a developer to trouble shoot the issue.
Hint - put a breakpoint on the first line in Info class > add method.
Helo Sir,
I will check that and will tell you sir… Thank you very much for your reply sir.
Thanks and Regards,
Kevin
