The total internal size of the records in your joined SELECT statement is 49468 bytes, but Microsoft Dynamics is by default performance-tuned not to exceed 49152 bytes.
i got this error message while click on hr worker
The total, internal size of the records in your joined SELECT statement is 49468 bytes, but Microsoft Dynamics is by default performance-tuned not to exceed 49152 bytes.
i try to do server configuration database tuning
but the max it is kept 48 already
can any one help me to fix the issue
Any changes to the standard form?
Also check if the Keep update objects config keys are enabled, disable them if you are not using them.
docs.microsoft.com/…/tune-data-access-settings
