The SQL database has issued an error.
When i opened the AX application following error is showing in infolog:
Cannot select a record in Country/region (LogisticsAddressCountryRegion).
SQL error description: [Microsoft][SQL Server Native Client 11.0][SQL Server]Invalid column name ‘MEMBEROFCUSTOMSUNION_RU’.
SQL statement: SELECT T1.COUNTRYREGIONID,T1.ISOCODE,T1.ADDRFORMAT,T1.CURRENCYCODE,T1.TIMEZONE,T1.ADDRESSUSEZIPPLUS4,T1.ISIMMUTABLE,T1.BACENCODE_BR,T1.OKSMCODE_RU,T1.MCRIOR_FACILITY_ID,T1.RPAYPARENTCOUNTRYREGIONID,T1.MEMBEROFCUSTOMSUNION_RU,T1.RECVERSION,T1.PARTITION,T1.RECID FROM LOGISTICSADDRESSCOUNTRYREGION T1 WHERE (PARTITION=?)
Can anyone help me on this…
Can you try by doing a Full synchronization ?
thanks for the reply.
I will and let u know.
