hi all, when i try to install AOS along with CONTOSO Demo database am getting error msg as “the selected database is not a model store database” but if select default database MicrosoftDynamicsAx db its not giving any error, am able proceed further, only am getting this error when i try to install AOS along with contoso DB. any one suggest me some ideas to resolve this error… thanx in advance
how did you resolve this issue? Currently I am having a similar issue. I installed the Database on a SQL server with the AX installation DVD and called the Database “MicrosoftDynamicsAXRTM”. The installation created two databases:
a) MicrosoftDynamicsAXRTM
b) MicrosoftDynamicsAXRTM_model
perfect…
Now i am trying to install the AOS on a second (application) server. Validation did not issue any problems.
when selecting the database “MicrosoftDynamicsAXRTM” the system issues the error “The selected database is not a model store database.” ??!!
hi NavToAXDevNewbie gud morning
install database along with AOS
after that restore the CONTOSO Demo database on installed database from SQL server
this will help you to solve your problem
