The record number does not comply with the original number. If the table uses entire table cache, this may be caused by the cache being flushed. Restart your job if this is the case.]
[Cannot edit a record in Purchase order lines (PurchLine).
I m facing same problem while updating PO line.After confirmation of PO(workflow enabled) I m trying to update PO line received now quantity…for some po it is working fine but for some po it is throwing the above error…
select forUpdate _purchLine where _purchLine.PurchId == ponum && _purchLine.LineNumber == DNLine.LineNumber;
ttsBegin;
if(_purchLine)
_purchLine.PurchReceivedNow = DNLine.Qty; //my customized qty I m passing
_purchLine.modifiedField(fieldNum(PurchLine, PurchReceivedNow));
_purchLine.doUpdate();//as workflow enabled it will not allow me to use update method
ttsCommit;
Where is the error thrown from? From doUpdate()?
Have you checked whether _purchLine.RecId == _purchLine.orig().RecId? If not, what’s the difference?
Can you reproduce the problem in a simple job that others can run?
Now I am not facing any error while running my job.I removed all usage data & executed my class.It was running properly…I am not sure actually where the problem was…
