The property UnifiedLogonAllowed does not work on our data base (resident on server with Windows NT4 sp3); that it’s in YES or in NOT, Navision Financials does not use the same procedure of connection as Windows NT, thank you for your of help, Benoît. formateur@ideaa.com B.Durand
What version of Navision are you using? Do you have your NT User ID defined properly in the Navision security table?
Yes, I created a user in table which has the same user code and the same password as the user NT. Benoît
quote:
Originally posted by Jim Hollcraft: What version of Navision are you using? Do you have your NT User ID defined properly in the Navision security table?
B.Durand
I use the french version FR 2.01B (FR2.01A).
B.Durand
Hello, Do you have any message when you open your database or just ask for user and password? I have the same problem until i found that i must set the UnifiedLOGON to Yes AND THEN OPEN THE SOCIETE BY FILE/SOCIETE/OPEN and not by the shortcut which kept the old configuration in zup file. Best regards,
