the program could not connect to a server error on RTC connection to Nav Server
Below are the steps/processes carried out:
  1. I used Three tier on two computer architecture.
  2. The SQL Server 2008, Database Components (Nav 2009), and Nav Server(Nav 2009) Installation were successful for the Server end.
  3. The Client installation was successful too i.e. Role Tailored Center
  4. But the Role Tailor Center Client could not connect to the Nav Server
I will be glad if you can help me out.
Hi Mikhali,
Can you brefily explain your problem where you stuck? I could not understand what exactly you want?
:frowning:
/Nitin
