System: Win2000 SP3 SQL 2000 SP2 CommerceServer 2002 IE 6 Attain 3.60 I get the following messege then I try to connect to my commerceportal. ---------------------------------- The page cannot be displayed There is a problem with the page you are trying to reach and it cannot be displayed. -------------------------------------------------------------------------------- Please try the following: Click the Refresh button, or try again later. Open the kontman1 home page, and then look for links to the information you want. HTTP 500.100 - Internal Server Error - ASP error Internet Information Services -------------------------------------------------------------------------------- Technical Information (for support personnel) Error Type: Commerce.AuthManager.1 (0x80070057) AuthManager(CommerceServer): You should call ‘AuthManager::Initialize()’ method with a valid site-name, before calling any other AuthManager API. /commerceportal/Default.asp, line 10 Browser Type: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.0) Page: GET /commerceportal/Default.asp --------------------------------- Why do I get this messege???, I cant find anything wrong in my configuration and the syncronization works fine.
Do You have the correct site name in csapp.ini? /Lars
Yes I think so. csapp.ini look like this: SiteName=CommercePortal AddressKeyName=CommercePortal RelativeURL=CommercePortal Path=C:\Inetpub\wwwroot\CommercePortal AbsoluteURL=//KONTMAN1/CommercePortal PackagePath=C:\Program Files\Navision Attain\Commerce Portal\pup\CommercePortal2002.pup I installed the PUP in the default web site. The fist time I try to connect to the site I get this messege: Error Type: Commerce.AuthManager.1 (0x80070057) AuthManager(CommerceServer): You should call ‘AuthManager::Initialize()’ method with a valid site-name, before calling any other AuthManager API. /CommercePortal/global.asa, line 77 Browser Type: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.0) Page: GET /commerceportal/Default.asp But if I uppdate the page I get an error on line 10 instead: Error Type: Commerce.AuthManager.1 (0x80070057) AuthManager(CommerceServer): You should call ‘AuthManager::Initialize()’ method with a valid site-name, before calling any other AuthManager API. /commerceportal/Default.asp, line 10 Browser Type: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.0) Page: GET /commerceportal/Default.asp Browser Type: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.0) Page: GET /commerceportal/Default.asp I have checked all the settings in Attain att least ten times, I just dont get this.
Check out these: 1. Check the SQL table COMMERCE_WEBSITE to see if the ASP_File_Folder field name has the correct content specified. This field is set up in the ASP File Folder field on the Web Site card. To check the field in Attain, click Commerce Portal, Web Sites. 2. Check the site name in the csapp.ini file. The file is located in the root of the Commerce Portal site. 3. Check that a connection to the Commerce Server Manager can be established. In the manager snapin, verify that the SQL Server user name and password is correctly set up for the Commerce Server. 4. Check that there aren’t any read-only files in the Commerce Portal Web site directory. 5. When unpacking the Commerce Portal Website, be sure that you are logged in with local system administrator rights on the Commerce Server 2000/2002 computer.
I have the same problem. But… its dont work! 1. Table COMMERCE_WEBSITE is correct 2. .ini is correct 3. Connection established. 4. All files arent read-only 5. Im unpacking pup-file under domain-controller administrator. In the Event Viewer appear some messages: Event Type: Error Event Source: Commerce Server 2002 Event Category: None Event ID: 32769 Date: 05.03.2003 Time: 18:34:26 User: N/A Computer: COMMERCE Description: In BindArgs::OpenDataSrc(), failed initializing data source (-904429548) Event Type: Error Event Source: Commerce Server 2002 Event Category: None Event ID: 32804 Date: 05.03.2003 Time: 18:34:28 User: N/A Computer: COMMERCE Description: Error: failure in catalog resolve, hr: -2147483326 Event Type: Error Event Source: Commerce Server 2002 Event Category: None Event ID: 32788 Date: 05.03.2003 Time: 18:34:28 User: N/A Computer: COMMERCE Description: Catalog Load failed catalog: Profile Definitions (-2147483326) Event Type: Error Event Source: Commerce Server 2002 Event Category: None Event ID: 32773 Date: 05.03.2003 Time: 18:34:28 User: N/A Computer: COMMERCE Description: DataSource::Init(DS-1[Class Factory]DS-2-Profile Definitions) failed on catalog load (-904429548) Event Type: Error Event Source: Commerce Server 2002 Event Category: None Event ID: 4097 Date: 05.03.2003 Time: 18:34:31 User: N/A Computer: COMMERCE Description: Error: 0xCA178005 DataSource::Init(DS-1[Class Factory]DS-2-Profile Definitions) failed on catalog load (-904429548) source: Microsoft Commerce OLE DB Provider Whats wrong???
Hi, I encounter similar problem before. Not really sure if this will work, try to open the global.asa file and do some modification and save it. Try to access the commerce portal again. cheers Steve
Did you unpack CommercePortal2000.pup as well? I think the CommercePortal2002.pup is just an upgrade. Also, use IE5.5 SP2 instead of IE6.0.
Synchronize the commerce portal site from …\program files\navision attain\commerce portal\sysnchronize folder using the exe file available. If it goes smooth then there is no problem of OS. Also ensure you operating system is Windows 2000 server and not professional. Ram
