the object metadata does not exist. identification fields and values object type='page' object id='90026'
Hi Every body,
I’ve got the Problem Created Sales Order In RTC.Click on Sell-to Customer No. field Name then
the object metadata does not exist. identification fields and values object type=‘page’ object id=‘90026’ Error message Appear
Compile the page once again and try
Raj
I have already Compiled all the Pages
But no use Same Error
Do you have 90026 page?
if yes, run the Object Metadata table and filter on page 90026 and delete.
Compile again and try…
hi
The problem is there is no page 90026 in the object designer.
Then the page 90026 must be used somewhere in Sell-to Customer No. lookup or validation etc.
export all objects and search for Page 90026.
Did you compile all objects and didnt get any error?
did you delete 90026 from object metadata table?
Delete the record from Object Metadata table and compile the object again…
The Record not Available in Object Metadata Table
Did you try by exporting all objects in txt format and searched for 90026?
If you do not have the page object no. 90026, then that’s your problem! And you will not be able to compile or run it.
So you’re getting the error correctly because it doesn’t exists and your code say that it’s supposed to exist. So you should instead look into the code (on the sell-to customer no.) - but you should really just check with your developer. If he or her created a page 90026, then they should know it!
Venka,
Did you solve your problem?
