The Microsoft shared Fax device not printing in the Navision financials 2.6 D spanish versión, the problem is if you are select the option print and select a printer titled ‘Microsoft shared Fax’, the driver are question then phone of send , name and other, otherwise Navision is a pop and are window on/ window off, a pres the control to driver printer, and are impossible press OK or write one character in the printer device. Tanks. mms
The problem can fixed by modify the report you are trying to send, Change the report property “ShowPrintStatus” to No That solves the problem Sorry I didn’t see this sooner, just found your post searching for a shared fax problem of my own. David
