Since there is no exist API for Transfer Order until now, I created my custom API to Save and Retrieve Transfer Orders, While retrieve/Get is working fine, I can not Post a new record as a Transfer header, The error I am getting is:
"error": {
"code": "Internal_RecordNotFound",
"message": "The Transfer Header does not exist. Identification fields and values: No.='' CorrelationId: 13c5d54d-61da-4667-a6b3-fd79b9ef6d58."
I do not provide the ‘No.’ field, because If I did I will receive this:
You may not enter numbers manually. If you want to enter numbers manually, please activate Manual Nos. in No. Series T-ORD.
(And I should not do activate the manual No. process.)
I am not able to insert any new Transfer Header record.
Any idea or help much appreciated
