Hello,
I’ve been searching for a solution for this and I cannot find anything. I have a user using a Windows 7 Professional x64bit computer running NAV 5.0 SP1. NAV is running fine, except when they go into the purchase module and attempt to send a purchase order to a PDF by pressing the “PDF” button on the PO they receive the following error:
This message is for C/AL programmers:
The call to member Send failed. MAPIMessages returned the following message:
The computer has MailOCX 1.00.01 installed and registered in the Custom Controls area (I have even tried re-registering MailOCX). The PDF button looks like a standard NAV feature - I have not touched any of the coding behind it (we don’t have a dev. license). This function works perfectly fine on Windows XP computers.
The user can bullzip documents just fine and is using that as a workaround; however, it is inconvenient for them. If anyone has any insight into this issue and what I can do to resolve it, I would be extremely grateful for your advice! Feel free to let me know if you need more details.
- C
