Hi, Is there a way to just make a string in a textbox partly bold. Let’s say: I have a textbox with sourcexp=AccountInfo. AccountInfo is a text variable. AccountInfo will be: ‘Customer No.’ + format(Customer.“No.”). The actual Customer.No needs to be bold. Is that do-able in this text string? Thanks, Roelof.
Hi, You can not do this.
Roelof, I think you have to split it up in two text boxes. The problem is probably the different length of the text if you are using text variables. Sometimes the text could be ‘Customer No.’ and sometimes maybe ‘Vendor No.’ or something else …
why not have 2 text boxes… maybe if you can predict max length of first one, you can make second text box without borders an lay over first one, so that it appears as one text box…
Yes, I guess this is the only way to it: 2 boxes. But it was given a try. Thanks. Roelof.
