TextBox - AssistEdit property
Hello,
I have a textbox on the request page of a dataport.
I set AssistEdit property to yes, because I would like to open a file with it. But the button is not active, I mean nothing happens when I push it.
Is there anything else to set in order to work?
Thanks a lot,
Frida
Did you also write
CommonDialogMgt.OpenFile(Text006,’’,2,’’,0);
in - OnAssistEdit()
Where CommonDialogMgt is codeunit Common Dialog Management
…or the old trick to set in the properties of the TextBox the ID to 1
