Hi, Is there a way to put in order a text sales line?. So i mean only a comment line with some information on it? Regards Wim
Yes. Set the Type field to blank (first option) and put your text line in the description field.
Wim, yes that’s possible, the only drawback is “where”. The easiest way which requires n ocustomization is using the order lines, select line type " " (blank) and write your text in the description line. In fact, this approach is used with the “Extended Texts”. These texts will then be printed as normal in your sales documents… Hope this is what you are looking for - because other solutions like printing before the lines header or at the end would require some customization. Saludos Nils
