Text field in Item details is stored in which table?
I am not able to get the table name fo the text field in item details form (General Tab). It shows
Name_M_txtDefault
InventTable.txtDefault()
Can any one help me out to find out the table and field name where this field is stored.
Regards
Dhamu
It is an edit method, that a look at the table method:
//BP Deviation documented
edit ItemFreeTxt txtDefault(
boolean set,
ItemFreeTxt txt
LanguageId languageId = CompanyInfo::languageId();
InventTxt inventTxt = InventTxt::find(this.ItemId,languageId);
if (set)
ttsbegin;
inventTxt = InventTxt::find(this.ItemId,languageId,true);
inventTxt.ItemId = this.ItemId;
inventTxt.LanguageId = languageId;
inventTxt.Txt = txt;
inventTxt.write();
ttscommit;
return inventTxt.Txt;
The field comes from the InventTxt table that you set up from: Item details form>Setup>Language item description
