text compare tool for chinese
i am current doing some merging, but because the original object CaptionML was modified to include some chinese character, thus when i did the merging in beyond compare tool I was unable to view the chinese characters. Anyone can suggest a better tool?
You need to use the Upgrade tool kit avaliable for NAV, you can approach you partner for that.
Hi Nikeman,
Whenever I compare objects which have different languages, especially if the new, old and customized versions does not have the same languages installed, then I always start by removing these languages. You can do this from Tools → Language Model → Export. Remember to select/mark all the objects first.
After you have exported and deleted the languages (never remove ENU) then it’s much easier to compare.
And when it comes to compare, then I can suggest that you use something like Mergetool.com instead of Beyond Compare, if you are merging more than just a few objects.
hi eric,
thanks for your replying, when i did the export objects left with enu only, thats perfect.
however after completed merging can i reimport all captionml back?
when i tried to import language module it doesn’t work [:(]
hi
hi akhilesh,
i cant find your reply…
regards
When you reimport the language file then you have to do the same as when you exported. You need to mark/select all the objects first. This is a feature which allows you only to import the language to the objects you want.
