I’m running a “test database” (3.7) on a database with 60 companies. When I have an error, is there a way to know the source company of the error? I thought about backing up a cie, restoring it in a blank db and test it, but I’d like to find a more simple solution.
Aren’t you in a company when you get an error?
Negative. The “test database” function will test all companies (opened or close) and will return ALL errors in ALL companies, regardless of which company is opened.
Oh I see, you’re running the ‘test database’ function, I thought you were running a database called ‘test database’. I don’t know how to do that.
