I have installed AX 2012 R3, I am trying to import demo data using Test data transfer tool. I have completed all the steps recommended by Microsoft but during running the dp.exe on command prompt i am facing the issues.
Actually, we have multiple instances of one server and i wanted to import the data into one of instances of sql server. for that i need to write the command line.
Can anybody suggest the actual command line?
Below is the command i have tried with, if anything wrong, you can advice here also.
DP.exe IMPORT “C:\R3DemoData\DynamicsAXR3DemoData” MicrosoftDynamicsAXR3 "Server\instance1"
Jagadis
