Test connection failed-ERROR [IM002] [Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified
Hi there,
I am using Dynamic AX 2012.
In control panel ODBC(32bit), I added a “DB_32_AXDEV” (DSN) 32 bit and tested successfully.
The SQL Server 2008 is installed in a 64bit Windows server.
In Dynamic AX client, I go to DIEF(Data Import Export Framework), Source data formats.
Add a new connection.
DSN type: System DSN
DSN location: SQL
Name: DB_32_AXDEV (32 bit)
Connection String: Driver=Oracle in OraClient11g_32;DisableRULEHint=T;Attributes=W;FetchBufferSize=64000;NumericSetting=NLS;ForceWCHAR=F;FailoverDelay=10;FailoverRetryCount=10;MetadataIdDefault=F;BindAsFLOAT=F;BindAsDATE=F;CloseCursor=F;EXECSchemaOpt=;EXECSyntax=F;Application Attributes=T;ResultSets=T;QueryTimeout=T;CacheBufferSize=20;StatementCache=F;Failover=T;Lobs=T;DisableMTS=T;DisableDPM=F;BatchAutocommitMode=IfAllSuccessful;Description=DB_32;DBQ=DB;UserID=AXDEV;DSN=DB_32_AXDEV;
As I clicked the Validate button, I got “Test connection failed-ERROR [IM002] [Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified”.
Could you please give me any hints on this error?
Thanks in advance.
Phil
Hi there,
Ok, I gave up 32bit ODBC and go back to 64bit ODBC.
I set up a new ODBC like my previous post.
In classes, there is a class named as DMFHierarchyValidation.
connectionStr = _dmfDataSourceProperties.dsnConnectionString + ‘uid="’ + _dmfDataSourceProperties.dnsUserName + ‘";pwd="’ + cryptoblob2str(WinAPIServer::cryptUnProtectData(_dmfDataSourceProperties.Password)) + ‘";’;
As I debug this class, I found uid was empty. That means _dmfDataSourceProperties.dnsUserName was empty.
It cannot get the username from the server, even it can get DSN name from server.
So I modified this line and hard-code the uid as the name I set in control panel->ODBC(64bit).
Then when I click the Validate button. I got test connection sucessfully.
That’s the whole procedure I have done.
Wish it can help someone with this kind of error!
hi there,
i am using 64bit using as sytem dsn in AOS, in server the connnetction works fine. but in AX connection validation fails.
when i submit the password , i get the following error
pls help
Driver=Oracle in OraClient11g_home1;DisableRULEHint=T;Attributes=W;FetchBufferSize=64000;NumericSetting=NLS;ForceWCHAR=F;FailoverDelay=10;FailoverRetryCount=10;MetadataIdDefault=F;BindAsFLOAT=F;BindAsDATE=F;CloseCursor=F;EXECSchemaOpt=;EXECSyntax=F;Application Attributes=T;ResultSets=T;QueryTimeout=T;CacheBufferSize=20;StatementCache=F;Failover=T;Lobs=T;DisableMTS=T;DisableDPM=F;BatchAutocommitMode=IfAllSuccessful;Description=;DBQ=ORACLE-TEST ;UserID=testapps;DSN=Oracle Test;
Oz
