Temp File
Hello,
I am facing a problem in microdsoft dynamics nav with temporary file again and again its showing error message. cannot use the file c:\documentsandsetting_temp\temp\temp_*(any no).temp because its already in use.After error message navision restarts.Pls suggest some solution.
Nishtha
Try the following:
  1. Delete the “fin.zup” file, this file should be in
c:\Document & Setting\User Name\Application Data\ fin.zup
and open NAV again.
If the above doesn’t solve the problem, re-install NAV.
Nishtha, take a look at this thread, too:
http://dynamicsuser.net/forums/p/21524/103654.aspx
Although it doesn’t give you full solution, there are discussed reasons why this happens…
