Hi, i 've got a little problem while converting my 2.60 database technically to 4.0 SP 1. (the database is already running on 3.70) the sql error is (translated from german): 208,“42S02”,[Microsoft][ODBC SQL Server Driver][SQL Server]Unknown Object Name ‘Object’. 16945,“42000”,[Microsoft][ODBC SQL Server Driver][SQL Server]The Cursor has not been declared. SQL: SELECT O.“ID” FROM “Object” AS O WHERE O.“Type”=? ORDER BY O.“ID” May be it is a hint that the virtual table Object is called Objekt in german database…the 4.0 SP 1 version is german also… Has anyone an idea???
How exactly are you converting the database?
i open the database withe the 4.00 sp1 client. after the confirm to convert the database the error message applies.
Given the big difference in versions I would really recommend doing a backup and restore as opposed to a simple convert. Try that and let me know if you still get the error message.
